-15%
Aeotec
Wallmote Quad
Art.nr: ZW130
696:- 819:-
Lägsta pris de senaste 30-dagarna: 696 :-
Trådlös fjärrkontroll för Z-wave-system. Stödjer upp till fyra enheter med stöd för 16 olika kommandon via olika gester. Ger feedback med både inbyggda dioder och vibrationer. Kan även agera som egen kontroller utan gateway. Levereras med magnetisk monteringsplatta samt Micro-USB-kabel för laddning. Stöd för AES 128-bit-kryptering. Z-wave Plus-certifierad.
WallMote is the wall switch that you can install anywhere. Wirelessly. Whatever the room, whatever the wall, WallMote is perfect. It is the wireless, Z-Wave wall switch that you can place anywhere, on any wall, with as little as double sided tape. Unpack it. Stick it. Charge it. Control is just a tap away.
It is great as the wall switch that you can place anywhere. But WallMote is also the wall switch that you can use anywhere. Designed for simple recharging and portable use, WallMote’s magnetic mount means that you can simply pull it away from the wall it is mounted on whenever you need it somewhere else. WallMote. Coffee-table-Mote. Bedside-Mote. Anywhere-Mote.
Press and hold. Swipe up. Swipe down. Tap. Through capacitive touch, each of these lets WallMote do something different. Dim lights on a whim. Open curtains to let in a little bit more light. Through the power of touch, WallMote does not just offer whole home control, it offers precise control on demand.
Control a light. Control a room. Control a home. Because WallMote communicates directly with your Z-Wave gateway, it can be used to control anything that your gateway can. Even things that are not Z-Wave. Smart lighting from Philips Hue? Check. Connected music from Sonos? Easy. If it is connected to your gateway, simply add it to a scene that WallMote can control and it is on top.
Features
  • Remote switch with a 4 button touch-surface
  • Z-Wave Plus
  • EU frequency: 868,42 MHz
  • Vibration feedback when operating
  • Slider function
  • Integrated color LED indicates status
  • In the box:
  • WallMote
  • Back-Mount Plate
  • Double-sided tape
  • Micro USB cable
  • Quick start guide
Talks to Homey: Ja
