Philio Tech
Multisensor 3 in 1 - Motion / Light / Temp
Art.nr: PHI_PST02-1B
459:-
The Z-Wave Plus 3 in 1 sensor is designed with three detection sensors: PIR/Motion temperature illumination
The detector can be used as a security device or home automation device. When the detector is cooperated with security...
  • PIR/Motion
  • temperature
  • illumination
The detector can be used as a security device or home automation device. When the detector is cooperated with security appliances, the detector is acting as a security device by detecting changes in infra-red radiation levels. If a person moves within or across the devices field of vision, a trigger radio signal will be transmitted to cause full alarm condition in order to frighten intruders away. Once night falls, the percentage of ambient illumination is lower than preset value. If a person moves within or across the devices field of vision, a trigger radio signal will be transmitted so as to turn connected lightings for better illumination. Every time when PIR trig, the sensor will also send temperature and illumination value as well. Also the temperature will send out the value when temperature changes.
When included securely the device is able to accept secure commands and to send secure commands to other devices. The commands and the receiver of the commands sent out on single click and on double click of the rocker can be defined in configuration parameters and association groups.
Please note: The Illumination report is not the LUX value. It is a percentage of the measured LUX between 0 and 1000LUX. I.e 1000LUX will generate the value 100 in the report.
Batteri ingår.
Ersättningsbatteri kan köpas här.
Typ av sensorer: Rörelse
Typ av sensorer: Temperatur
Typ av sensorer: Ljus
