-10%
Mnu Nano v3 - CH340
Art.nr: Mnu_nano_comp
116:- 129:-
Lägsta pris de senaste 30-dagarna: 111 :-
OBS detta är en clon/kompatibel version av Arduino Nano v3. Kortet har CH340-chip som USB->RS232 converter. Drivrutiner hittar du här.
Mnu Nano is a surface mount breadboard embedded version with integrated USB. It is a smallest, complete, and breadboard friendly....
Mnu Nano is a surface mount breadboard embedded version with integrated USB. It is a smallest, complete, and breadboard friendly. It has everything that Diecimila/Duemilanove has (electrically) with more analog input pins and onboard +5V AREF jumper. Physically, it is missing power jack and power select jumper. Since the Nano is automatically sense and switch to the higher potential source of power, there is no need for the power select jumper.
Nanos got the breadboard-ability of the Boarduino and the Mini+USB with smaller footprint than either, so users have more breadboard space. Its got a pin layout that works well with the Mini or the Basic Stamp (TX, RX, ATN, GND on one top, power and ground on the other). Its a four-layer board with power and ground planes to help provide ICs with sufficient charge during switching and reduce noise (EMC) on high speed switching I/O pins. Ground plane help reduce radiation (EMI). Power plane is low in inductance; therefore any transients that may develop on the power line will be at lower levels.
You end up paying less with Nano than Mini and USB combined!
Features:
Automatic reset during program download
Power OK blue LED on the bottom
Green (TX), red (RX) and orange (L) LED
+5V to AREF jumper
Auto sensing/switching power input
Small mini-B USB for programming and serial monitor
ICSP header for direct program download
Standard 0.1 spacing DIP (breadboard friendly)
Manual reset switch
Power:
The Arduino Nano can be powered via the mini-B USB connection, 7-12V unregulated external power supply (pin 30), or 5V regulated external power supply (pin 27). The power source is automatically selected to the highest voltage source.
Microcontroller: Atmel ATmega328
Operating Voltage (logic level): 5 V
Input Voltage (recommended): 7-12 V
Input Voltage (limits): 7-12 V
Digital I/O Pins:14 (of which 6 provide PWM output)
Analog Input Pins: 8
DC Current per I/O Pin:40 mA
Flash Memory: 32 KB (of which 2KB used by bootloader)
SRAM:2 KB
EEPROM: 1 KB
Clock Speed: 16 MHz
Dimensions: 44x18mm
