-7%
IR sensor - TSOP38238
Art.nr: 157
14:- 15:-
Lägsta pris de senaste 30-dagarna: 13 :-
This sensor can be used with a Raspberry Pi!
IR sensor tuned to 38KHz, perfect for receiving commands from a TV remote control. Runs at 3V to 5V so it's great for any microcontroller
To use, connect pin 3 (all the way to the...
To use, connect pin 3 (all the way to the right) to 5V power, pin 2 (middle) to ground and listen on pin 1. It doesn't do any decoding of the signal, just passes the 'raw data' along. Check the TSOP38238 datasheet for more details
TSOP38238 Datasheet
  • Length: 5.20mm/0.21in
  • Width: 6.98mm/0.28in
  • Height: 7.86mm/0.31in
  • Weight: 0.43g/0.02oz
