IR sensor - TSOP38238
Art.nr: 157
14:-
15:-
Lägsta pris de senaste 30-dagarna: 13 :-
Bevaka Produkt
Bevaka produkt
Leveranstid:
This sensor can be used with a Raspberry Pi!
IR sensor tuned to 38KHz, perfect for receiving commands from a TV remote control. Runs at 3V to 5V so it's great for any microcontroller
To use, connect pin 3 (all the way to the...
- Specifikationer
Produktbeskrivning
To use, connect pin 3 (all the way to the right) to 5V power, pin 2 (middle) to ground and listen on pin 1. It doesn't do any decoding of the signal, just passes the 'raw data' along. Check the TSOP38238 datasheet for more details
TSOP38238 Datasheet
TSOP38238 Datasheet
Specifikationer
- Length: 5.20mm/0.21in
- Width: 6.98mm/0.28in
- Height: 7.86mm/0.31in
- Weight: 0.43g/0.02oz
