Italtronic
Din Rail Case for Raspberry Pi 2/3/B+
Art.nr: 25.041MP00.RMB
194:-
215:-
Lägsta pris de senaste 30-dagarna: 183 :-
Bevaka Produkt
Bevaka produkt
Leveranstid:
The Italtronic 4M Modulbox is a DIN rail mountable enclosure designed specifically for the Raspberry Pi Model 2, 3 and B+! The kit comes complete with a transparent, removable top panel for easy access and DIN rail hook for ultra-fast mounting....
- Specifikationer
Produktbeskrivning
The Italtronic 4M Modulbox is a DIN rail mountable enclosure designed specifically for the Raspberry Pi Model 2, 3 and B+! The kit comes complete with a transparent, removable top panel for easy access and DIN rail hook for ultra-fast mounting. The unit features 36mm internal clearance from the Raspberry Pi PCB to the top of the case, so there's plenty of room for GPIO mounted expansion boards.
¨ Since the indicator LEDs are moved on Pi 3, they are not visible thru the casing.
The Italtronic 4M Modulbox Features:
- Raspberry Pi DIN Rail Mountable Case for Electrical Domestic Cabinet 43880 STD Application.
- Wall Mountable
- Secure Clip-In Base
- UL94V-0 Self Extinguishing PPO and PC Material
- Dimensions (LxWxH) 90.5x71.3x62mm
- Transparent Panel for Easy Access
- Includes DIN Rail Hook
- Rev. 2 Raspberry Pi Board Mounting Points (Screws Included)
Downloads
Specifikationer
