-10%
Maxim IC
1wire temperatursensor DS18B20+
Art.nr: DS18B20+
62:- 69:-
Lägsta pris de senaste 30-dagarna: 59 :-
Denna sensor passar även till Fibaros Smart implant.
The DS18B20+ digital thermometer provides 9-bit to 12-bit Celsius temperature measurements and has an alarm function with nonvolatile user-programmable upper...
Denna sensor passar även till Fibaros Smart Implant.
The DS18B20+ digital thermometer provides 9-bit to 12-bit Celsius temperature measurements and has an alarm function with nonvolatile user-programmable upper and lower trigger points. The DS18B20 communicates over a 1-Wire® bus that by definition requires only one data line (and ground) for communication with a central microprocessor. It has an operating temperature range of -55°C to +125°C and is accurate to ±0.5°C over the range of -10°C to +85°C. In addition, the DS18B20 can derive power directly from the data line ("parasite power"), eliminating the need for an external power supply.
